- 12 May 2011
- Southampton
I'm after some fans that are a bit quieter and can potentially move more air than the stock Corsair ones, which are about 2 years old now. Any suggestions?
Have a look at the EK Vardar range, they have options from 1150rpm to 3000rpm.
OK so how about the same performance with quieter noise? Can I limit my stock fans to 1500rpm or less or will these still be loud compared to the fans listed above?
would agree with that. have 7 of the FF5's (3000 rpm) in my rig and it's overkill. my overclocked 8350 (4.9Ghz) at around 50-55c when gaming and the fans only spin up to around 1600-1700 rpm. have them on another AIO for my 290x and the same rpm's keep it at around the same temp. F3's or F4's really do give the best balance between silent idle temps and performance.im with you mate. EK Vardar 2150rpm is the sweet spot!
