better latencies or high speed ram?
2 Oct 2008
Im looking at this Ram 1066mhz
and this Ram 800mhz
Would i be better off going for the lower latencies and the lower speed or the higher speed with higher latencies. I will be overclocking but id have to do some very serious OC'ing to get the ram to actually run at 1066 wouldn't I? Although would the latency difference be at all noticeable or affect the overall system significantly at all? I'm a bit of a newbie in the world of OC'ing at the moment so not quite sure.
e8400 on asus p5e x38
Higher RAM speed. You'll have no issues using the Dominators at 1066. I've just sold a set which I had for 4 weeks. For benching I was able to hit 1134mhz and the e8400 at 4.2ghz ish.
Youll need to use 2.1v for the RAM to run it at those speeds, and my e8400 need 1.45v.
If you're going for massive clocks then get the PC2-8500, if not then it's only really benchmarks that will show the difference.
I'm loving the Dominators. Cheers Ben (Just need a beefy cpu to utilise the ram now!) :D
