Hi,
My son is in real need of a new PC (his old one will go to his sister), I have a budget of approx £500 (now updated to £600).
Ideally I'd like to give him my current PC and have the new one for myself, therefore the new one should be a better spec.
It'll be used mainly for gaming (LotRO) and some HD video editing (from video camera) along with the usual webby stuff.
My current spec is
Abit IP35-E (Socket 775) PCI-Express DDR2 Motherboard
Intel Core 2 Quad Q6600 "Energy Efficient SLACR 95W Edition"
XFX ATI Radeon HD 5770 XXX Edition 1024MB GDDR5 PCI-Express Graphics Card
GeIL 4GB (4x1GB) DDR2 PC2-6400C4 800MHz Ultra Low Latency Dual Channel
I need the case and everything that goes in it, no monitor, mouse, keyboard or O/S required. The case should have space for 3 extra hard drives which I will take out of my current machine into the new one.
Your challenge awaits
Thanks in advance
Willow
My current spec is
Thanks in advance
Willow
3GHz on Q6600s is usually hardly any effort, 3.2 is still usually pretty easy and most of the G0s can hit 3.6GHz with a bit of fiddling. If you leave the Q6600 at stock speeds you'll probably find that it will bottleneck the 5850 card so you wont really get the most out of it.
