Better of the 2 ??
21 Jun 2005
UK
Network newb here looking for a router to provide ADSL Broadband round the house via cable but also wireless if/when we get a laptop.
Had a D-Link once and had terrible trouble with it,e nded up selling it on the online auction site.
Had a a search about and ive narrowed the search down to either ...
Linksys WAG354G-UK 4-Port Wireless-G Broadband Modem Router
or
Netgear DG834PN 108Mbps Rangemax Wireless ADSL2
(both found HERE )
Intended for Gaming also.
Any advice on which would be the better choice?
Or can you recommend something better i haven't listed?
Thanks in advance, and if theres any you need to know to help me out just ask.
Chadd
Thanks for the replys guys,
but does anyone have either one the these specific models and can recommend it?
Is the Linkseys easy to setup?
Thanks again for any feedback.
Chadd
My friend does and he's never had any problems. IMHO they are easy to setup.
Any router will work fine with a 360, or any other device.
At worst, you might have to forward ports (if the router doesn't do uPnP), but that's hardly going to break anything.
