Any router is better than the SuperHub.. Just make the superhub modem only and then use your choice of router. Cisco linksys's range of higher end stuff is very good.
You should just be able to plug it in after disabling wifi on the superhub.. (The wifi really is terrible isn't it!). The VM hub has gigabit ports so you might want to make use of them somehow, they are fast!
Do you really need something different? If it is just a wireless thing then just get some wireless access points. Unless you really need a feature not provided by the suberhub I wouldn't go into the trouble of getting an extra router to use.
