- 14 Jul 2013
- UK
Hi all! I would like to ask, is their a better cooler than my current NH-D14? Ive looked at many reviews and it points me into the direction of a custom loop, which I don't realllly want. I don't mind a AIO, but do prefer air if I'm honest. Also it seems my NH-D14 is better if not on par with 90% of AIO's? Would it be a better idea to keep my current cooler and upgrade my case for better air flow?
Atm I use a customised Corsair 100r, this is due to me needing a smaller case as it fits into my TY stand furnature. I have removed the lower drive bays, side mounted the SSD, drilled the front panel, all to allow maximum air flow. I have 2x 140mm Corsair high static pressure fans at the front blowing in, 2x 120mm Corsair high flow fans blowing out and a 140mm Noctua fan on my NH-D14 also blowing out. All fans set to max speed. And as you can see, the NH-D14 JUSSST fits in my case.
Current temps are Room ambient of 25*c, Inside case 28*c, Idle Average 35*c and I see a max average temp of 79*c after 30 mins of NON AVX Prime 95 Small FFT'S.
CPU is delidded with Conductonaut and Im using Krayounaut between IHS and NH-D14. Overclocked to 4.8Ghz @ 1.280v under full Prime load. All cstates etc are off, so constant 4.8Ghz even at idle.
Since my case temp and room temp are only 3*c different, I assume I have enough air flow and my case isn't an oven? My GTX 1080Ti idles at 28*c.
Rest of spec and pictures below. Excuse the dust, was before my current rebuild. I fully stripped it and done a Z370 build. Any comments much appreciated.
i7-8700k @ 4.8Ghz Delided / Noctua NH-D14 / T'Grizzly Thermals
Asus ROG Maximus X Hero / 16GB TG Dark Pro "8 Pack Edition" @ 3200Mhz
Crucial 480GB / Zotac AMP! Extreme Core GTX 1080Ti / Corsair RM750X
