better than mITX ? mDTX
21 Oct 2009
I just won bidding on famous polish auction portal :D
mobo is FOXCONN GL6E mini DTX board
I paid abour 30eur incl delivery
I think I get it directly after new year
I want to use it with asus 9400GS gpu (low profile of course) + maybe hi end asus xonar pci-e card powered nby picopsu 150W XT
So that little bit longer than a mini-itx to allow for the additional expansion slot. Not a bad idea, though unless you are making custom cases like yourself it'll be damn hard to find a case for it.
I'm guessing you don't have the right connector for the power socket?
dont have yet, but i bought two already, I hope will be arrive in next week
sorry i might of missed it but, better how?
bcoz cost me 4-5x less than 9300itx model and if you want use pci-e gpu will be no diffrence in performance
also you can plug good PCI-E gpu card + good pci-e x1 audio card
nd still case can be lot smaller than matx
From memory, 100% copper coolers are actually worse at dispersing heat than copper and aluminium ones.
Copper is very good at absorbing heat but not as good as aluminium and losing heat; which is why cooler baseplates are copper but the fins are aluminium. Also copper is more expensive and weighs a load more.
But copper looks loverly
If that's the cooler you're installing it with you'd cry if you saw mine.
Stock Intel and I think I might have to go even smaller to a Silverstone Nitrogon (looks like stock but 36.5mm high).
