better than
1 Jun 2017
i have a phantek enthoo pro case
can anybody reccommend a better case that has more space absorbs heat better even sturdier build can accept a lot of fans accepts liquid cooling i have the corsair h100i vs liquid cooler also i will be using a nzxt sentry 3 fan controller
i want to use neon lights in the case what do you all recommend thanks
Ah That is smaller than your Pro the 400c , that pro you have is really good for Fans & Aircooling ,
You would have to look for a bigger case
what do you recommend as a bigger case thanks with same feature and more than phantek enthoo
Corsair Carbide 600C Full Tower Inverse Gaming Case - Black Window (CC-9011079-WW)
Upto 360mm rad & Easy Door Open , Optimal Fans , would be 2 on front , 1 on top rear , 1 on rear , All you need , With A Rad , instead or with
Fans included: 3 x AF140L noise optimized 140mm fans.
- Cooling Layout: Front: 2 x 140/120 mm (2 x 140mm included), Bottom: 2 x 140, 3 x 120mm, Rear: 1 x 140mm (included)
- Radiator Compatibility: 360mm: Bottom, 280mm: Front or Bottom, 240mm: Front or Bottom, 140mm: Front, Bottom, or Rear, 120mm: Front, Bottom, or Rear
Corsair Graphite 760T V2 Windowed Full Tower Case - White (CC-9011074-WW)
Thermaltake The Tower 900 Super Tower / Showcase
You would need to look in the Full tower Area to Get better than you alredy got
