Hello all,
I am relatively new here, never posted before but have been reading these forums for a little while now and wondered if anyone would be kind to spec me a new build.
I have been doing a little research, and also getting very confused as there are so many opinions on which bit of kit to use, so this is what im looking to get out of the rig within a budget of £1200 +/- £100:
Upgradability - i would like the option to be able to add an extra GPU / other components in the future, hence i've been looking at PSU's larger than 550w
Case/PSU - exterior design not all that important, just the ability to keep all of the components cool and cables tidy. The room the pc is located in can get quite warm, so cooling would be key.
Use - Primarily for gaming, would like to be able to use it for new releases for as long as possible, with games such as Planetside 2 & Arma 3.
Monitor, keyboard & mouse - Not required, i am looking to run games in a resolution of 1920 x 1080p (HD) on a 24" monitor.
Storage - I would like to run the OS and some other core programs on an SSD, for the rest a 1tb HDD should be fine.
OS - Windows 7
I am basically looking for the best "bang for my buck" in a machine. Thanks for your time and looking forward to the responses!
OS - Windows 7
