- 31 May 2009
My folks have a reasonably new windows 7 PC.
All has been functioning nicely until a few days ago my father informed me he couldn't check his email.
The issue currently is browing to googlemail brings an error report in the browser. The standard browser message when you have no internet connection, offering the network connection dialogue and troubleshooter. 'We cannot connect to xxx.' or similar. Same situation you would get if you pulled out your network cable.
After investigation I've found, every single webpage I try works, all fine, outlook works, hotmail works, windows updates works, all net connections seem intact, and google itself works flawlessly, until you click the mail button within google or 'sign in' within google.
Direct browsing to gmail.com or googlemail.com brings the same error, as does using bookmarks to take you there. I am stumped.
I cleared cache, no help.
I reset the browser to basic settings, no help.
I switched all off and reboot the router (which is a BT thing btw), to no avail.
MSE shows no infections, same with superantispyware and malwarebytes.
Windows network diagnostics reports all as fine.
Anyone ever seen this? Any ideas what could be causing it?
