If you're after the best performance from your 'phones you'll have to seriously have to think about getting an amplifier. I have a set of Sennheiser HD650s that have an impedance of 300ohms. I can run them from an MP3 player without an amp but they sound no better than a much cheaper set of cans. I use a Graham Slee Solo amp which I enjoy and which has a formidable reputation amongst audiophiles, cost something over £300, but without knowing your budget or requirements I wouldn't recommended you to buy any particular product.
Perhaps you chose the Beyers before you had fully thought out your intended use. You could for example bought a set of cans with a lower impedence, e.g., Grados, some Sennheisers, AT and others, that don't require the power of an amp to drive them. However, you are where you are so I suggest you browse a more specialised forum for advice and information on getting the best out of your new 'phones. Have you tried the forums on headfi.org.
I have a Prelude Xfi and I must say that I've been less than impressed by its headphone output. My Solo amp has two inputs, of which one is connected to my Denon AV amp, which in turn is connected via a coaxial digital connection on the Prelude. The other is connected to the headphone connection on the Prelude. Thus, I am able to switch my headphone amp between the two merely by flicking a switch. I notice a distinct drop in quality and volume when I switch my headphone amp to the Prelude headphone connection.
I have a spare headphone amplifier, designed and built by Alex Nikitin, formerly the chief designer at Creek audio. See this thread for a discussion of its merits
http://www.head-fi.org/forums/f5/n-t-amber-impressions-113912/index2.html
This cost me over £200 three years ago and I reckon it's worth about £50.00 now. If your interested get back to me. If not, enjoy your Beyers.
