Beyerdynamics mmx300 how to improve sound?
14 Jul 2011
Hi I have the BD MMX300 headset and only have onboard sound. What is best to pair them with? Do I go internal or external. The main use for the headset is gaming. I see some people say get external DAC some say go for a pcie card.
TIA
Well for gaming, I imagine you'd want to be able to locate positional sounds? So you'd want something with Dolby Headphone or SBX, which rules out just a DAC, as they provide stereo sound with no effects for gaming.
There are external and internal options, so depends what you are looking to spend.
If you're not fussed about the 5.1/7.1 surround sound effects, and would prefer just decent stereo, then there are some good external DAC/amp options. You'd still need to connect the microphone to your onboard audio though, as DACs are output only.
