Beyond Divinity Patch ( REMOVES STARFORCE!!! )
Caporegime
8 Sep 2006
On Ocuk
I nearly fell out of my chair when i saw this LOL , man for like 3 months i was campaigning for them to remove it now a year later they do
A new patch (1.49) for the English version of Beyond Divinity is available. It removes the Starforce protection, fixing a number of problems players have been reporting including Windows Vista compatibility. Click here to download it.
http://www.riftrunner.com/
It took them long enough, really does annoy me, install game, start game, reboot, start game again another reboot.
Starforce, just say no :D
In any game that uses startforce and doesn't have a patch for it (for removing) i just use a crack even though I bought the game, there's no stupid protection telling me to reboot my pc, i hate rebooting, also whines about deamontools if its on, any game that removes it is a step in the good direction, shame you have to use warez or illegal .exe's to be able to game normally while continueing your other stuff (in this case keeping deamon/alcohol120%/isomount running) and without rebooting.
Thats the problem there never was a NOCD for this game only the polish version, it was probably one of the only SF games that never had a nocd. Plus the fact the amount of patchs this game had.
But now you can install the retail - patch and play without starforce :D
WARNING... just read on another forum that the game still installs starforce even if you havent loaded the main exe . This person seems to suggest that after install when it asks you to reboot your computer , dont click ok but ctrl+alt+del and kill the DRIVERINIT or something service relating to starforce. This should stop starforce from being installed on reboot , if you are worried run the starforce removal file after doing the above.
Still that is so f--ing lame
snowdog said:
In any game that uses startforce and doesn't have a patch for it (for removing) i just use a crack even though I bought the game...
Does that mean you never have to install Starforce in the first place? I have CMR2005 and Xpand Rally sitting here (the latter I've never played!), but I can't play them as the StarForce drivers won't work on x64 :( and if they did I wouldn't install them anyway!
