Anybody removed the bezel from their BenQ GW2750HM yet?
I've bought three articulating wall mounts for mine but I'm a bit worried that the VESA mounts are part of the casing/bezel and not part of the monitor itself.
Thanks ChefWil.
You're right it does mention the VESA mounts but only their size. (as far as I could see)
Having watched a few video's about debezelling and read a few forums I was concerned that the VESA mount might be part of the casing and not part of the metal structure inside.
If this is the case then debezelling isn't really an option for me.
However if the VESA mount is part of the internal structure then I'll try debezelling all 3 of mine.
Let me know how you get on, that monitor is one of two I'm trying to decided whether to buy for gaming with an Xbox and I'll be using the VESA mounts to.
What are your thoughts on the Benq ?.
Also considering a Dell S2740L.
