So EA's crappy cases basically duffed my BF2 original disc, cracked it all the way up.
I used to just play with the SF discs, but if I am to install again I would only be installing BF2 SF, not the original.
Anyway I can get BF2 original back on without paying for another disc?
they may try to blame it on you not putting the disc away properly but if you say it was through no fault of your own then it should be fine.
