BF2 help for a noobie.
Man of Honour
16 Mar 2005
Clevedon , Bristol
Just bought today and installed.
Am i right that the 1.41 patch is the one to install ? EDIT: Sorry just seen the thread below :o / i'll stick with 1.41
There is no option in the video set-up for 1280 x 1024, is this correct ?
At high/max settings 1280 x 960 or 1024 x 768 are the max it offers.
I am using a Gainward 24 pipe AGP 7800gs+ ,so it should handle it no problem
Mark
You can edit the target field in the shortcut to the exe that makes it default to 1280x1024 (Or any res you want actually), google for it.
Or do that ^ :p
