BF2 on a LAN against bots???
2 Jan 2004
Chesterfield
I am having a mini-lan with some friends and we want to play BF2 co-op against bots.
I know we can start a single player game on a 16 player map and all join via the IP address connection but is there any way to play on any of the bigger maps co-operatively against bots???
Cheers,
StevieP
on a similar note, is it possible to have a 64 man map against bots, not bothered about a LAN, im trying to learn to fly jets, but you can only bomb so many static targets.
pretty much all the co-op mods work. the V2, V3 and V4 all by Distro. (above link)
you only have 32 bots i think, but they are on the bigger maps, and usually with added extra's. i.e. a blackhawk in strike at karkand for the USMC.
some of them are a bit unstable and they dont have all the maps in them, some mods have diff maps to others, but their all vcool.
if you want even more bots then use the bot changer mod. its a tiny program you launch BF2 from or the co-op mod from after selecting how many bots and what difficulty you wnat (can select upto 255 bots i think, but it runs liek a dog with this many bots lol)
you can set bots manualy in 'Battlefield 2\mods\COOP_4.0\coop_def_ai.ai'
open with notepad and in there will be two aiSettings.setMaxNBots, goto the one without a rem before it and change 32 with however many bots you want.
