BF2 Problem After Install
9 Nov 2004
West Midlands
I've looked as well as I can through that HUGE thread and can't find the answers to my problem. I've just formatted my system done a fresh install of XP and after installing Battlefield2 when I get to the login screen it is all grey with just a white mouse pointer, any ideas what is causing this.
So far I've changed 6800U Drivers, updated to DirectX 9.0c Feb Release, installed all my motherboard drivers, changed bioses and this has still not helped, and also re-installed BF2.
Any further ideas will be appreciated, this is my first issue with this game ever!
Stu
sounds like the install is b0rked.
un-install and re-install to different directory and delete all the profile data (the bf2 folder in my documnets). but obviously save your keyboard mappings file
Done all the above and it is still the same, I'm just going to wipe it again the weekend or beat the **** out of it before the weekend gets here but we'll see.
Stu
Stu
Did you delete your BF2 folder in my documents ?
theres all sorts in there that caused problems for lots when patching.
I was in a similar situation a week or two ago, my problems in bf2 were sound related mostly but I also had a multicoloured log in screen for some reason, uninstalled windows reinstalled game but still had problems, I think I reinstalled windows over 5 times that day trying to sort the problem, took ages and then you got all the trouble of reinstalling software drivers patches etc before you see if it works.
Eventually I got it working still not sure how but the only thing I done different to the other installs was to delete and create a new partition and format the hard drive first, dont know if this was the cure or it just worked by chance, but im :) now its working and running smoother than ever before
I swore I would back up all my data/drivers from that nihtmare of a day, tried norton systemworks and ghost and that caused even more probs and had to reinstall again :( lol
[DW]Muffin said:
Which drivers are you using?
I'm using the latest nVidia driver 83.90's which before I formatted worked perfectly, I've also tried a few others but it is the same.
When I uninstalled the game this folder was gone also, so I didnt need to delete it although I'll do it again now to be 100% sure, I think it format time now though to be honest, I'm pretty good at solving problems but so far this one is beating me :(
Stu
Ok I've just installed F.E.A.R as well and that is the same except the screen is black with a white mouse pointer arrow, strange thing is Doom3 plays ok, I'm wondering if it is a DirectX issue?
Anyone know anyway I can revery back to DirectX 8.1 to do a fresh install of the latest 9.0c as this was updated by BF2 which is where I'm thinking the problem lies.
Stu
you cant roll back Direct X unless you use system restore to do so
but that obviously reverses ALL changes since then so probably not advisable.
guess its a re-format.
