Basically i went to video options and change my screen res, but choose the wrong refresh rate. So when i load the game up my monitor goes weird and i can only hear sounds and see nothing but a black screen.
Sounds to me like you have set the resolution or refresh rate to high and your monitor cant handle it...... if it does this before you can even get into the options then I can only suggest a full re-install.... give it a try... takes 20 mins at the most.
