BF2 resolution settings?
18 Nov 2003
Hey guys,
Just got myself the x1950pro, just wondering what resolution settings should i use with it?
I got a 22" inch widescreen monitor that runs at 1680x1050...
thanks a lot :)
It does work for me. You have to have a standard resolution set in the .ini file. For example I use 800x600. Otherwise it will crash to windows. It shows the resolution set in the .ini in options but in reality it uses the resolution set in the shortcut.
i just added this
"C:\Program Files\EA GAMES\Battlefield 2\BF2.exe" +menu 1 +fullscreen 1 +szx 1440 +szy 900
for my 19inch widescreen, works fin
u have to add it in the bf2 options in xfire aswel if u use it
fivefive said:
Hey guys,
thanks a lot :)
"C:\Program Files\EA GAMES\Battlefield 2\BF2.exe" +menu 1 +widescreen 1 +szx 1680 +szy 1050
Don't touch the in game reso once you've done this.
fivefive said:
Hey guys,
thanks a lot :)
Got an NEX 20.1 and if I run it at 1680 x 1050 it gives you a right headache !
Too small really, on a 22inch it maybe fine as the pixels maybe a little bigger.
It a right pain snipping at long distances at that res.
1440 * 900 seams good though.
