BF3 and 120Hz
13 Jan 2004
I run dual monitors, one is 60Hz, one is 120Hz.
I game on the 120Hz naturally. Whenever I launch BF3 despite being set to 120Hz ingame the monitor is actually only being driven at 60Hz. I have to change to a lower refresh rate, apply, then rest to 120Hz and re-apply for the game to run in 120Hz properly.
I have a feeling it is because BF3 launches in the background and pops the game up when ready but thought I would check to see if anyone else had the same problem and if there was any solution?
Disable the 60hz monitor then try and load bf3
I run single monitor setup and never had any probs! Have u set the Hz u want within bf3 and for the ccorrect monitor as u can choose monitor 1 or monitor 2 in thr bf3 settings!
