BF3 launch problem
28 Dec 2007
Sheffield
Posted in the big BF3 thread and on the EA forum but not had much help :(
I go to launch the game and am given the following error:
"a required security module can not be activated
the program can not be executed (1300)"
Posted on the EA forums too but no response, I've tried updating PB again and no luck. I select "Repair instal", and it's downloading 11gb of files !!
Cheers
at this folder HKEY_LOCAL_MACHINE/System/MountedDevices/
Right
Click the Mounted Devices folder, Click Permissions, Click Advanced,
Look under the "TYPE" header for any labels that say "Deny", if there
are any highlight and click Edit, Check Full Control and "OK". and voila
Top result from google. Do you have virtual drive software? Like Daemon tools.
Google seems to point to it being with virtual drives, google the error theres plenty of stuff. Don't put Battlefield 3 in the search.
