BF4 4k problems
13 Jan 2013
County Durham
Just got a new samsung 4k monitor and it's great with games I've tryed with it but bf4 will not go into 3840x2160, it asks if I want to keep theses settings and click on yes but it doesn't allow me to select and then reverts to 2560x1440 any ideas what's going on.
Just got a new samsung 4k monitor and it's great with games I've tryed with it but bf4 will not go into 3840x2160, it asks if I want to keep theses settings and click on yes but it doesn't allow me to select and then reverts to 250x1440 any ideas what's going on.
I had this problem but with steam and Win8.1 and went back to Win7
Are you running the screen @30htz or 60htz as this can cause it.
I'm now reinstalling bf4 to see if it makes a difference but if anyone else has come across this problem and has a fix I would love to know.
Try deleting the bf4 configuration files found in my documents. I had many issues getting bf3 to accept my upgrade to 1440p and this solved it.
Do you have oversample enabled in the BF4 video options control panel ?
I've reinstalled it and gone to the video setting and it was automatically on 2560x1440 tryed to change to 3840x2160 and it still won't do it, so help is needed.
