BFBC2 Lagg on PS3
6 Jan 2010
Leicester
hey guys
i brought a new tv for my ps3 old one broke
its a 42inch lg 1080p and cause of the massive size im getting fps lagg. is there anyway of getting the fps lagg out
could i get downscale from 1080p to 720p, will the lagg go?
im saying this because i cant take those moving sniper headshots without jumping a pixel it sucks cause on the beta my kd was somthing like 2.4-2.7 and now it is one
any one who helps me get a thank you and a cookie :)
also can a nvdiea geforce 210 play bfbc2 on pc ?
You shouldn't bump a thread so quickly.
The size of the TV shouldn't matter, usually there is a gaming profile in the options menu that disables processing to cut down on the input lag, also try to disable any other separate video processing options on your PS3 channel, on my TV they are called MPEG NR & DNR, they help smooth the picture over but they cause input lag.
If that doesn't help then there isn't a lot you can do I'm afraid.
Also a geforce 210 would really be struggling to run bfbc2, maybe @ 1280x800 (WS) or 1280x1024 (4:3) with all the settings lowered you might be able to shift it at an acceptable level, also depends on your CPU.
lag and low frame rate are two completely different things
and the FPS / frame rate has nothing to do with what TV you have, the game runs at a resolution the designers choose, and your TV stretches that to fit your TV. Bad Company 2 actually runs at 1280 x 720
The game is 720p anyway not that it would make much difference. Sometimes the game is laggy, there is a lot going on with all the different players its going to happen. Just join another game and try your luck.
Why are you worried about your k/d ratio? If you are worried about it then this game isnt for you. It's a team game. MW2 is a game of k/d ratios. I normally always finish just under 1/1 or slightly above on hardcore but I normally always finish in the top few on score and most importantly win the game.
Playing normal mode is where you want to get your k/d ratio up. You can easily finish a good 10/20 kills above your deaths and still get high scores. Just because your k/d was good in the beta doesnt mean you are going to be as good in the actual game. This game is a lot about knowing your maps.
The only other thing that it could be is connection. Playing wirelessly?
My connection isnt great. 8mb d/l and 1.3mb u/l but I normally get smooth running games 9/10 times.
MW2 is not a team of K : D
The Free For All game in mw2 is, but there are tons of teamplay modes like Search and Destroy that have very little reward for purely kills.
