BFG 260 OC Maxcore Overclocking?
13 Dec 2008
Hey i just got a 260 maxcore from bfg and am looking to overclock it, ive never overclocked a graphics card before and have downloaded riva tuner and evga
precision, are there any settings that are tried and tested that i can put into these programmes and get to work fine or are there many variables. thanks for any help i have no idea where to begin.
InfernoUk
im trying avga precision with settings
Core:700
Shader:1509
Memory:1200
Fan:61
Ive run 3d mark 06 5 times with no issues on a 6th run i encountered white flashes of the screen for a few milliseconds during the graphics tests im guessing those are artifacts? how should i fix this using the above settings or does it not matter if it was ok for the first 5 runs?
Well what was the temperature readings when doing 3d mark?
I'd be interested in how you're getting on cos I have the exact same card.
I would try something else for a test too..maybe the crysis demo benchmark.
Maybe try ati tool or furmark too.
I have got the following stable
Core:725
Shader:1554
Memory:1250
not tried for more, but I think with the fan at 100% I may be able to pull a few benchmarks at higher clocks
Usually you will get between 1458 and 1512 stable on the shaders (these go up/down in steps of ~54MHz), half that on the core and around 1200-1350 stable on the memory.
core: 700
shader : 1509
memory: 1200
fan: 61
are my evga precision settings and i get artifacts on the 6th run of 3d mark, whats needs changing to stop this? and how to i find out gpu temps underload in the best way?
