BFG 280 GTX rebooting system
16 Aug 2006
Help please. I'm not sure what is causing the problem, but when I play any games (crysis, Mass Effect...) after several minutes the system reboots. Sometimes it could be 5 minutes..other times it'll be 20+ minutes.
I'm pretty sure it's not a heat problem. The gfx card never goes over ~85oc
PSU is a Coolermaster 850W. I've got 2 HD drives in RAID, plus one optical drive. MB is an ABIT IN9 32 MAX.
Do need to RMA the card?
have you got another card to test out?It could be a different problem,have you got any other pci-e slots on your mobo?maybe trying the card in a different slot.
Just replaced an 8800GTX which was working perfectly.
Not sure how to test in a different slot - thought it only worked in the primary.
