BFG 680i Problems
6 Nov 2005
Aberdeenshire
just changed from a DS3 to a 680i but can't get it to boot.
The blue LED is on, on the board, but nothing happens when you try to switch it on. I've tried with the bare minimum hardware in, double and tripple checked my wiring. I've got 6 risers in the correct places in my case and still can't figure it out. I have both the 4 pin 12v wires in next to the cpu, am i right in doing that?
help greatly appreciated.
Thanks
Oh yeah and has anyone else got this board and found there was no CMOS battery?!?! It came from OCUK
I'm not sure but I don't think you're supposed to have the two 4pin cables plugged in. Either use one or if your PSU has the correct 8pin cable use that. One of those 4 pin cables is incorrect. Read your manuals.
