BFG 680i what cpu upgrade?
10 Aug 2004
Been away ages...completely lost track of things!
Any CPU's compatible nowadays that OC sell? I have a 5 year old core2duo in at the moment.
Thanks
Whoops, double post.
Also, your motherboard is not compatible with the Yorkfield 45nm quad cores (these are the die shrink from 65nm to 45nm of the Q6600 I mentioned which is a Kentsfield).
Thanks lollyhayes
Re: the q6600 - I use a DangerDen waterblock on my E6600, I don't suppose that's compatible is it? I won't bother to W/C the graphic's card if I upgrade but would like to on the CPU.
Thanks
Thanks lollyhayes
Thanks
No worries, danger den blocks are fairly good, you could definitely give it a go. As long as you aren't hitting high 60's 70's with it at the moment I imagine it would be good enough for the Q6600.
It certainly wouldn't kill it if you tried it.
From what I remember the 680i motherboards were quite poor at clocking quads so you may want to research if you intent to OC.
I still have a MSI 680i board in the cupboard that I couldn't get stable at 3Ghz with a Q6600.
Same chip is currently at 3Ghz in this board http://www.overclockers.co.uk/showproduct.php?prodid=MB-344-GI&groupid=701&catid=5&subcat=1490
though will do 3.4Ghz prime stable at 1.42V with a few tweaks though for air cooled fan noise I keep it at 3Ghz.
If you can find one at a sensible price the QX6700 or QX6800 were multiplier unlocked quad kentsfields that may be a better bet.
AD
As decto mentions the 680 chipset/motherboard weren't great with quads though there was a rev 2 revision of the reference boards (of which the BFG is one) which largely fixed the issues. You need to check the product number on the board to see if it's a rev2 and I also have a suspicion that BFG never actually sold the updated board.
Hmm, I used to have a Asus P5NT-WS nForce 680I and it got to 3ghz ok. Can't remember what revision it was though...
The extreme quads will definitely get you there, although at what cost, im uncertain.
I use to have a 650i board which I could only overclocked my Q6600 G0 to 3GHz max...and higher it would become unstable. After swapping out the crappy nforce board for a Asus P5Q Deluxe, my Q6600 is now running at 3.6GHz prime stable.
I think for a 680i board, you realistic expection for max overclocking a Q6600 is probably 3.0GHz...despite the only average overclock, a Q6600 G0 at £50 is a very good upgrade from the E6600.
I had the reference evga 680i a1 revision board. This was the updated, supposed quad friendly version. 3.0ghz was the most i could get from a q6600, didnt matter what settings, voltages i tried etc, it wouldnt take it any higher. It packed in so i replaced it with an Asus p5q deluxe p45 board. The same cpu topped out at 3.8ghz with ease in this board.
