BFG 7800gt settings
20 Jul 2006
Can anyone advise me on the best Nvidia settings for this graphics card please.
The only game i play at the moment is BF2 so if you can match it to that aswell i'll be very gratefull ;)
I use nHancer and don't use the driver settings, so I can configure each game with their own settings.
I would set the Negative LOD to clamp and set the Adjust LOD Bias to 0.250, all of this can be set within nHancer (Global settings) or the drivers. Also I set the Force Mip Maps to force trilinear.
Coolbits2 will "unlock" a lot of options within the drivers that is worth using.
If your in doubt just play around with the settings.
For BF2 I would set the res at 1200x900 and maybe x2 AA and x4 AF for decent fps.
Just FYI I have a 7800 GTX and im playing BF2 at 1280x1024 MAX EVERYTHING full AA and AF. And im getting completely lagg-less play on the system below... (However it was the 2GB which helped ENORMOUSLY!!)
are you having problems? i had a 7800gt with a 3200 once with 1gb of ram and i needed to run medium textures, but the rest was on full at 1280x1024 and it worked very well. 60+FPS iirc
yup only got 1gb of ram :( for the mo thinking of selling my comp to my dad and keeping the graphic card and just going conroa and DDR2.
Thing is if i set the res to 1280x1024 things might be a bit small as i only have a 19" LCD
Nothing is overclocked either so this doesnt help :D
its the ram your missiing out on, bump it up to 2gig and my 7800gt can cope with everything maxxed 1600x1200 and 4xaa on bf2, still smooth as anything :)
