BFG 7900GT OC - first overclock
10 Jun 2003
Just started to overclock my BFG 7900GT OC . I started out with the coolbits from the control panel and detected optimal settings.
It came up with 550 on the core and 800 on the memory . Now that memory reading sounds a bit low to start with ??? Or is it ?
Rivatuner will let me go much higher but I don't want to fry it !!!
I know all the stories about them 'being borked' and this has been RMA'd once !
Anyone else got one of these ? And what are you running it at ?
Hey, got one of these with a zalman vf900 fitted. I haven't vold modded it. for 24/7 Use i'm running it at 550/800 so what you've just detected :)
Remember you double the ram so thats effectively 1600Mhz.
Idle temperatures are about 38-39 and full load is a touch over 50.
I haven't volt modded mine, so whatever is stock. Actually have had the core higher but it needed slower memory speeds for some reason.
Ah right forgot about doubling the memory speed DOH !! :D
More than happy with this card , on with the tweaking !!!
550 / 815 for now ;)
Going to fit a Zalman VF900 , is it worth fitting the RAM heatsinks as well ????
