- 11 Dec 2005
- Brighton
Hi Folks,
My new 8800 is driving me crazy. I can overclock the core up to 620 which I think is not very good but the main problem is I can not overclock the memory at all. When I set up the memory clocks higher and run the test is ok even at 2500DDR because the clocks are not really changing. I tried with Rivaturner, Ati tool, Power strip and all of them allow to move the slider and run the test but the clocks still always at 1.58 GHz. I also install the ntune utillity and it doesn't allow me to change from factory clocks to custom clocks setting
I tried to install and remove the driver (97.92) and the utilities several times, I also tried Ngo optimized drivers which are base in 97.92 and still with the same problem.
I don't know what else to try but wathever I do the clocks are always 1.58 for the memory. I have been overclocking GFX for years without any problems .
what can I do about it? maybe a faulty card? Only option I have left is reinstalling windows XP or try older drivers but I doubt is going to change the situation.
BTW 3DMark06 reads wrong values for the card and says in details VGA memory clock 324 Mhz and core clock 108 Mhz
Bios version is 60.80.0D.00.04
My system:
Asrock Dual Sata, opteron 170, Tt 700W toughpower, 2GB ram etc.
I tried to install and remove the driver (97.92) and the utilities several times, I also tried Ngo optimized drivers which are base in 97.92 and still with the same problem.I don't know what else to try but wathever I do the clocks are always 1.58 for the memory. I have been overclocking GFX for years without any problems .
My system:
