having slight problem with my gtx it seem it's under performing. you wouldn't notice ingame it's fine it just when i have been doing 06 test to see what improvment am achieveing with my oc, i realised that my gpu score are down by 900/1000 point compared to similar system's. i have the forceware 97.92 driver's on stock setting on gpu.
e6600 3.2 oc with stock gpu setting's i only get 10573 same score i was getting before overclocking cpu.
any help appreciated
zia
p.s should my pcie 16 lane's be set to auto as they are currently? has my over clock affected them?
system spec is in sig
zia
