Hello,
I maybe bit off more than I could chew with my latest build. My shiny new 9800x2 arrived today and I can't get it working.
I'm using a Asus Striker II Formula nForce 780i and coolermaster 1000W PSU. I install the card, hook up the power cables but when I turn on my comp, my LCD Poster just says "VGA Bios". All the lights on the card are green. Not sure whats wrong at all.
The slot works fine as I've tested it with another card.
Hope someone can help so I can get this beast working.
Thanks
Thanks
. Hopefully it won't be too long. Even hassle Asus for a beta so you can use your card for now. I'm sure they'll have something that will help you but if they will release it is another thing.
Been putting this rig together last couple of days and what an experience. First raptor drive problems now this. I'll get Vista setup and start playing with the 8500.
