BFG RMA - quick question
7 Mar 2005
I sent back a 256MB 7800GTX OC VIVO Dual DVI card for replacement, am I likely to get a 7900GTX (seeing as 7800GTXs aren't made anymore)?
If they aren't in production anymore then It's likely you will get the 7900. I would have thought they would match a card that has similar specifications or value!
:) You may get a 7900GT if they have any as its pretty much equal spec to the 7800GTX. More likely to get a GTX tho. If youre really lucky you may get an 8800 :)
