Hi,
I've recently brought a BGT3620 and I've been experiencing an issue when viewing HD channels which I cannot work out. But before I continue I'd like to list down a few specs before I continue.
Computer:
Motherboard: Asus P8P67 Pro
CPU: Intel Core i7 2600k
RAM: Kingston HyperX 8GB (2x4GB)
Graphics: Nvidia 8800GTS
Sound: Sound Blaster X-Fi Fatal1ty Edition linked to 2.1 speaker set-up
PSU: XFX 650W XXX Modular Edition
Hard Drives: 1x 60GB OCZ Vertex SSD With Windows 7 and 1x 1TB Samsung Spinpoint F3 For Data
TV Card: BGT3620
Operating System: Windows 7 Home Edition
Main Monitor: LG Flatron W2363D 3D Ready running at 1920x1080 @ 120Hz
2nd Monitor: Dell Something running at 1280x1024 @70Hz
Windows is fully up to date patch wise and has all the latest drivers for all hardware applied.
Transmitter: Sandy Heath which has been through the digital switch-over.
Distance away by road: 6.4 miles
Can the transmitter be seen from the house: Yes
To save me trying to explain my issue and possibly confusing you along the way I've made a video so you can physically see the issue yourself.
As you can see from the video I start off at BBC One HD and you can clearly see the stuttering picture which doesn't clear up if I leave it. Then as I move channel it seems to keep some of the previous picture as well as a pixelated picture of the channel I'm on and so on. Strangely through the BBC Preview which is the last of the HD channels worked fine at the time. I just tried it again but with live golf on this time and I get the same problem as the other channels.
Just to prove that it isn't just a weak signal I move onto some non-HD channels and they work perfectly.
Things that I've tried. To me that showed all the symptoms of a low signal. I run a little indoor aerial seeing as I can see the transmitter. (http://www.argos.co.uk/static/Product/partNumber/5344857/Trail/searchtext>AERIAL.htm) So I went out a brought a plug in signal booster which boosts the signal up to 20dB. Tried that and if anything it just made the picture even worse then what it was. I then tried a utility called Vista/7 Media Center Decoder Utility to changed the media decoder in case it was that. But the few video codecs I had to choose from just brought up a decoder error in the media center.
So as a last resort I went out today and brought 6 Meters of aerial cable so I could plug into the house aerial socket. That feeds to a proper big aerial which is located in our loft. That video above was taken with the loft aerial connected and it has made zero difference. So now I've hit a brick wall because I have run out of ideas. I'd like to think I've ruled out low signal as a cause. I believe my computer is beefy enough to watch Hi Def TV. So I don't know if it's a bug with the cards hardware, the drivers for the card or weather it's Microsoft’s Media Player being funny. I did try spending a few hours trying different TV viewing apps. But seeing as there is only 2 products on the market that pick-up DVB-T2 it's hardly surprising that they all failed to pick up the Hi Def channels.
Edit: I've just found a trial app that does pick up the HD channels and they display and work fine. So I'm lead to believe that it's some kind of software issue.
Thanks a lot to anyone that has read this far and helps out.
Computer:
TV Card: BGT3620
But from the bit I wrote above, plus VLC playing back the footage fine and being connected to a roof aerial it seems to me it's a conflict of software somewhere.
