BHS Silly Discounts
Can't type for toffee
Don
14 Jun 2004
Newcastle U/T
Been after the circulon elites or some of the raymond blancs for a while now.
Just spotted on HUKD that BHS site is currently doing silly discounts!
I just got the Raymond Blanc set for £70, couldn't resist.
Stacked the following codes:
I used code BHS50 for 10 off 50
code BHS40 for 10 off 40 homeware
EVENTMAR13 20% off
Just finishing work but will have another look when I get home in case theres anything else I fancy.
http://www.hotukdeals.com/deals/bhs-discount-codes-working-together-e-g-28-00-off-60-spend-1500975
Did you do the £25 off a 100?
:eek: I need to find some money fast
Edit - should look at total. It doesn't apply all vouchers. Still extra £5 using VC100 code.
YEah missed the 10% nhs code tho in case they ask for proof as setup for store pickup
Very tempted to order the circulon elite spoons n stuff tho
Topcashback is tracking instantly too £3.53
Im now looking at my order and it says may take upto 10 days to get to store :(
Might cancel and reorder lol
Dont see how they could catch that tho :)
Shoudl read a bit more before making my order lol
Looking at 8 of the circulon utensils for £40.40 delivered or picked up from store do I hit buy :unsure:
Would certainly be better for the new pans than my battered old ones lol
So that plus the pans should work out at: 103.40
Cheapest I can get them too with the codes is £113.26 if I order them together :/
Why not just get it all delivered, it's free.
In case they decide to start cancelling orders, they have my money and I can pop to local store.
when I put the NHS one in my price went up :p
Yeah seems like fiddlign with the order of codes if worth a look.
Some knock others off
Am I being blind, or do they not have any stand mixers, like kmix/kitchen aid.
http://www.bhs.co.uk/webapp/wcs/sto...d=-1&categoryId=&searchTerm=mixer&pageSize=40
Only one I can see
wont the 205 one get picked up on if you don't use BHS mastercard ?
Paid my initial order thru paypal discounts applied fine.
and 5% topcashback for the cheeky among us :p
Removed the £7 circulon elite ladle (cant remember the last time I used the one I have)
And it reduced my cost from £40.40 to £33.60
Only code that works for me is the £10 off £40.
March event one does not work, the bhs 50 and 100 ones apply, but do not actually discount the price.
