- 4 Jan 2009
- Cheshire
Hi all, I've just bought B&W 684s for my Onkyo 609 and just setting up Bi-Amping the speakers.
Just need a little help with it as it says in the manual on the 609 the TOP speaker terminal bindings should go into the 7.1 (surround back or front high) section in the back of the 609 and the bottom speaker terminal bindings should go into the normal FRONTs section of the 609 amp, now I have done this but when I run Audyssey it doesn’t seem to want to pick up the Surround back or front highs that have been connected with the TOP bindings of the speakers.
I have now tried plugging the TOP speaker terminal bindings in the Surround section of the amp and Audyssey has picked up these but I'm not sure it is completely correct doing it this way? Does anyone know if this is completely working the Bi-Amp now or does it have to be in the 7.1 section of the amp?
Also it did set the Surrond cross over in the setting to 45Hz and the Fronts to 150Hz so I set the Surronds to 150Hz also is this correct?
Thank you!
Thank you!
