Im currently highest bidder on a 2000cc N reg xantia (only £155) to use to get to work.
It has two problems the seller says:
One, the suspension doenst pump up.
And two, the ABS light is on and stopping is a bit dubious, but its got a couple of months T&T on it so i figure, if i get it for a couple of hundred notes its a gamble i can take if i can get it sorted cheaply or just bang it straight back out again if i cant.
So whats the deal with the suspension? they recon they had a new part fitted and that sorted the problem, and it might "need adjusting"?
And what could be the ABS problem?
I'm half an hour from a Specialist Citroen breaker for bits and bobs, and the workshop at the depot will fit parts for me, i'm just after a rough idea how much i'm going to be looking at shelling out.
