Biffa - Me needs help...
18 Oct 2004
Cumbria
Rather than continue in an old thread - I've started a new one...
Quote:
Originally Posted by Biffa View Post
Loudbob if you need a hand let me know
I tried updating the bios using the Modified bios and afudos.....
Used the following command (in dos):
AFUDOS.EXE G60NG4.A11 /P /B /N /C /R
Also tried:
AFUDOS.EXE /iG60NG4.A11 /P /B /N /C /R
Both gave the same response:
USAGE: AFUDOS /i<ROM filename> [/o<SAVE ROM filename>]
Any thoughts?
EDIT: Nevermind - looks like it's flashing - must have had wrong flash utility
Edit Edit: Flashed OK and CPU's upto 2.53GHz - but Memory dropped from 1333MHz to 1066MHz ???
are you using the Elysium? Make sure you get some airflow, is it the watercooled or aircooled rig you bought? If water then you need to force some air over the heatsinks. If aircooled you should be ok.
Glad you got the flashing sorted out, I've just gone back to the latest stock bios as the 62xx chips don't work with the OC bios, you have to push them using tpc.
Going to swap them over tonight.
Yep, using the Elysium
got some noctuas on the cpu's blowing up and out of case, got 4 x 120mm in front of case blowing into the cpu's (think they're 1900rpm's - good air flow), the 230mm (ithink) on side blowing in and a 120mm noctua fan on back blowing in.
nice n cool inside case - cpu's maxed at 43c :)
