- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Hey guys
A new option for all your overclockers, watercoolers and phase change guys! (Hardware inside not included, but you get the idea) I will have more images next week to showcase more detail.
Stock is still about 4-5 weeks away though.
Tech Labs XL Full Tower Case - Black/Red @ £199.99 inc VAT
Meet the beast of all beasts! The Behemoth to rule them all. This epic case will be able to house the best of the best with watercooling and even phase change unit being no issue. The images show what the case is capable of. Pictures offer so much more than our words can......
- Dual housing design provides highly expansible capability of HDD
- Adjustable top dust cover to control the air flow
- V360mm.GA length limitation is
- Space for dual cooling systems installation is able to fit 360mm water cooling in main body and 480mm in top system
- Side panel with dust filter is easily cleaned
- Able to fit into HPTX Motherboard
- Drive Top System: 2x5.25", 2 x 3.5"(Hot Plug), 4 x 2.5" (Hot Plug)
- Main Body: 4 x 5.25", 6 x 3.5"(Hot Plug), 2 x 3.5"(hide)
- 4 x 2.5"(Hot Plug)
- (top system) Top: 12cm x 4 or 14cm x 4 / 480mm water cooling
- Rear: 12cm x 1 Cooling Fan
- (top system) Top: 12cm x 3 or 14cm x 3 / 360mm water cooling
- Side: 20cm x 1 or 12cm x 2
- Rear: 12cm x 1 Front IO Main Body: USB2.0 x 2pcs & USB3.0 x 1 & HD Audio
- Top system: USB2.0 x 2 & HD Audio Motherboard Micro ATX / ATX / E-ATX / XL-ATX / HPTX LED Indicator - Power & HDD Power Supply (optional)
- Dimensions (D) 605 x (W) 230 x (H) 780mm
Only £199.99 inc VAT.
ORDER NOW
ORDER NOW
