Big cardboard boxes?
18 Dec 2008
Liverpool
Any idea where you can buy big one cardboard boxes? I need something 880x420x680 mm and can't find anything on line that meets my requirements I need to ship a bulky item.
something i have done in the past is joining 2 smaller boxes, using a good amount of overlap and plenty of packing tape its pretty strong
I don't know if you have a "Mail Boxes Etc" near you but they will make up boxes for you. I had them make one for a PC tower once as I'd chucked out the original. Can't remember the price unfortunately.
Seems like most online companies won't do what you require or you have to order 250 boxes. :D
Could ask at a supermarket?
Go to local businesses who sell big stuff and ask if they have any spare boxes.
I find womens clothing shops have insane amounts of really good boxes.
Thanks guys, I'll try your suggestions. Tried the self storage places and they don't have what I need.
Thats a bit of a "custom size" there, I can find boxes which exceed two of the three dimensions you've given but can find anything "of the shelf" that is close, but I can find boxes that are far, far bigger than than you need i.e. - https://www.cardboardboxes.co.uk/product/pallet-boxes-double-triple-tuff-wall-various-sizes/
This is the minimum thickness box, probably not ideal for shipping to someone else but its cheap -
But as its for shipping I'd consider a thicker (& more expensive) box like these Tri-wall which we used in the military for packaging -
That’s quite a URL they have there. :D
