- 12 Jun 2011
- Near Overclockers
Hi
After buying my first decent CPU cooler - the Corsair A50 - I can't get it to fix onto my motherboard because the pressure is too great for the heat sink attachment thingy (sorry to be technical).
It has actually snapped it off, so my PC is presently on its side (great).
What do I need to take the load?
It is on an AM3 board, so it is attached using only the clamp (or whatever it's called).
Any help would be great.
Thanks in anticipation.
AD
AD
