- 12 Jan 2006
My build:
-AMD Opteron UP 165 Dual Core San Diego 1.8GHz 2MB Cache (Socket 939) - Retail (CP-151-AM)
-DFI LanParty UT NF4 Ultra-D (Socket 939) PCI-Express Motherboard (MB-014-DF)
-HIS Excalibur ATI Radeon X1900 XT 512MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail (GX-048-HT)
-Western Digital Raptor 74GB WD740GD 10,000RPM SATA 8MB Cache - OEM (HD-015-WD)
-G.Skill 2GB DDR HS PC3200 (2x1GB) CAS2.5 Dual Channel Kit (F1-3200USU2-2GBHS) (MY-007-GS)
-Seasonic S12 600W Silent ATX2.0 Power Supply (CA-002-SS)
-Zalman CNPS9500-LED Aero Flower
The problem is that the chipset and the PSU seem to be running very hot, around 50 oC, this causes all sorts of alarms to go off.
My problem is that the fan on the powersupply never seems to go above the 800 mark even with the PSU is hot.
And the chipset fan doesnt go over 7k.
I didnt notice this before as i didnt have the PSU plugged into the motherboard monitoring (i have it plugged into Fan 2)
How do you advise i fix this
or am i just being paranoid and i should increase the alarm temps?
I do have the system oc'd from 1.8 to 2Ghz by setting the FSB to 222Mhz, but the rest is running as it comes out of the box
