- 26 Oct 2009
- London
few years have passed since my last post, but im once again planning a project.
edit: just realised i posted this in the wrong forum.. doh.
anyway...
ive got a fairly interesting custom machine.. its a standard lian li alu case, but with 2 microatx machines crammed inside. they are both overclocked 3930k's with 32gb of ram, connected with 10gb infiniband, and powered by a shared 1500w psu.
one board is used as the main machine (and has a gtx670 gpu) the other is a rendering slave with no gpu.
i use it for my work doing 3d animation.
i always intended to document the build here, but as always, real life got in the way.
anyway im very happy with the result apart from one thing. the noise.
each cpu is cooled with a corsair h80 with push/pull fans ( yes they are in the same case too)
however, with a 4.4ghz overclock, both need to be running on high. and the combined noise of the two coolers (plus gpu when im working) is starting to drive me a bit bonkers (not to mention i have tinnitus to remind me of all my youthful partying, but thats another story)
so, i was thinking about building an external cooler that could handle both 3930k's, and ideally a couple of titan-x'es (my prospective next purchase for gpu rendering)
it would also be nice if the cooler had spare capacity to cool another machine should i choose to add one.
it also has to be as near to silent as possible.
tall order eh?
so my current thinking is a pair of mora 3's with a set of 4 180mm fans sandwiched between them (with a space to remove dead spots) with a nice wooden or metal frame wrapping the sides and top.
also included in the cooler would be reservoir and pumps (2 for redundancy / extra pressure)
i figure that even with say, 3x 6 core oc'ed processors and a couple of titan x'es, 2 mora 3s should be more than sufficient, and definitely the most cost effective compared to other options.
thoughts?
next up, the issues of tube length, loop layout, restriction ,and pump selection.
id like the option to situate the cooler in the room during winter, but during summer ( south of italy) it hits 45 degrees C here, so id like to move the cooler into the nice cool outhouse that backs onto my office space.
this will require a distance of at least 3-4 metres from the workstations to the cooler. all on the same level though.
would a pair of ddc 18w pumps in series be enough in this case? if one dropped out would one limp along till a replacement?
id imagine also, doing the entire loop in series, to avoid issues.. i dont know if this is practical with 2-3 cpu blocks and 2-3 gpu blocks.
i do have the option to run the mora 3-s in parallel. i heard they can be restrictive (although this is debated) so maybe having them in parallel would be good.
phew ok. thats got the general idea out. any thoughts?
anyway...
tall order eh?
thoughts?
