big fitting on Supremacy?
You may consider starting with a 45' angled fitting on the block, if it fits with your build looks.
That way you should be able to avoid any problems with clearance.
my set up dosent really call for 45/90's so if i can i would like not to use them.
But thanks for the idea i will order fitting and it stuck for room i will drop an 45 in
I had a similar thought, but opted for the ek ltx block due to the largest spacings for fittings.
Already have the block fitted and it good with the 19mm tubing but some of the barbs dont feel super safe. I have put zip ties on them but it dont loom super though the window
It should be ok. I have 7/16" (11/16mm) compression fittings on my Supremacy Evo and there is 7-8mm between the fittings once fitted and tightened up. My fittings are cheap no brand ones that are cosiderably larger in size than the 11/16mm XSPC onse I also have. You would hope that EK's own fittings would fit their blocks, especially when they use a Supremacy Evo in the 4th photo.
I don't have any 13/19 on hands but the OD of our ACF 13/19 is 24mm and I checked it on a supremacy EVO with my caliper and they would fit.
