Big mouse
30 Aug 2006
Im after a big wired mouse, i went and bought a Logitech and didnt realise it was a note book type so its very small. Im after something for a medium to large hand and with a long cable (at least 1.5m)
Im also not looking into paying much no more than £10 if possible. I like the comfort grip ones but not fussed about extra buttons. I saw the Gigabyte M6800 but not sure how long the cable is.
If that one ^^^^ is too big!
Possibly something by Logitech, I always found them comfy and I have really large hands.
I find Logitech far too cramped and I have normal sized hands. I think the Razer mice are a good shape for larger hands.
Oh sorry didn't see the budget.
Was going to suggest a saitek rat 3 but then remembered the 3 is non adjustable :/
You can adjust the rat's to fit all size hands but the 3 has no adjustment options.
Another option is a steelseries ikari optical, I've owned one and its both wide and long (ooo-er).
RATs may be adjustable, but they are insanely ugly.
Also the optical Ikari has major MAJOR mouse prediction. This means that when you drag in a nearly straight line it will smooth it out into a perfectly straight line - absolutely dog**** for games. There's no way of turning it off.
I don't have any suggestions really, just commenting on other's.
