big problem please help
30 Nov 2007
just reinstalled win7.
everytime i reboot im getting BOOTMGR missing, yet if i set my system to boot from cd but dont press any key to boot when prompted it boots ok. its just when i set it to boot direct from hdd.
my hd boot prioritys are correct, also for some reason my 3rd hdd isnt showing either ??
any ideas ??
Boot into the windows 7 disc again and select repair your computer, then get it to check for startup problems. It may just be a problem with the boot manager with any luck and not a hosed install/dying drive.
Unplug all hard drives, boot from DVD and do a repair, should work, I have had the same issue.
If repair doesn't work a fresh install with only the C: will.
One thing I have noticed, when i install win7 there is no longer 100mb of unallocated space above the c: ssd, I dont know if that's got anything to do with it ?
( were I select drive to install onto )
Omg !!
Just reinstalled but before I did I gave the disk a quick rub, hey presto
Amazing, wasn't even dirty
Working after a quick rub a dub dub
