Big problem please help
5 Sep 2013
UK
So i just got my replacement for my graphic card as i though that was the problem which was just cause my motor to go black and say "no signal" I have no idea whats wrong. Who crashed just said this
On Wed 09/10/2013 21:39:02 GMT your computer crashed
crash dump file: C:\Windows\memory.dmp
This was probably caused by the following module: Unknown (0x00000000)
Bugcheck code: 0x116 (0xFFFFFA800A3374E0, 0xFFFFF8800FA3BA88, 0xFFFFFFFFC000009A, 0x4)
Error: VIDEO_TDR_ERROR
Bug check description: This indicates that an attempt to reset the display driver and recover from a timeout failed.
A third party driver was identified as the probable root cause of this system error.
Google query: VIDEO_TDR_ERROR
Like i said i got a new graphic card and still same problems
My spec i got zotac gtx 770 4gb
msi z87-g45
corsair 750w psu
And it cant be the drivers as i just did a reformat and installed everything new. I got the latest ones is well. Thanks for the help guys
I have not overclocked anything what so ever :( and i dont understand what u mean about the Ram. This is a brand new system which i have built
Wanted to add when i run in safe mode works fine, when i replaced my grahic card with an old gtx 460 worked fine, is it that maybe the zotac will not work with an msi board?
well you can use ram testing software to check if it is your ram that is causing the problem, but since you've said that your 460 card works fine in there I'm more then positive it's a driver problem with your 770 card or the card itself. How old is your psu?
And have you tried an older driver for your Zotec card. You can try uninstalling your current drivers and trying an older one to see if it's more stable.
PSU is new, and i think it is the drivers but i dont understand why it wont work , is it just the zotac company maybe ? maybe if i get the msi version of this card it will work fine? and yes i tried older drivers and it not work, i think maybe the zotac brand and msi motherboard not meant to go together lol
I don't think it's brands that won't work together, may be an issue with the Zotec card, have you tried the card in another computer?
Ye this is a replacement sent for my first one as i thought it was faulty but this is not working is well, unless i am the unluckiest guy in the world, anyway i put my gtx 460 back in put the latest drivers for it, and stress tested it now and everything is working fine, So i do reckon that zotac wont work with msi motherboards , i cant think of anything else
sadly there is that chance but I would hate to replace it again for the problem to re-appear.
have you removed old drivers etc?
ye i removed old ones tried new ones etc with the 770 nothing , every time i stress it boom comp gose , i tried the 460 which is a standred nivdia brand and it worked perfectly , i stressed it and all fine, so ye i think god knows how going to have to call up etc and get an msi version or something
