Big problem
16 Jan 2004
Morning,
Just done a new build and getting some problems so could do with some expert advice.
AMD Phenom II X2 Dual Core 550 3.10GHz Black Edition (Socket AM3)
XFX ATI Radeon HD 5770 1024MB GDDR5 PCI-Express Graphics Card
Geil Value 4GB (2x2GB) DDR3 PC3-10666C7 1333MHz Dual Channel
Asus M4A78LT-M LE AMD 760G (Socket AM3) DDR3 Motherboard
OCZ ModXStream Pro 600w Silent SLI Certified Modular Power Supply
Samsung SpinPoint F3 500GB SATA-II 16MB Cache
Samsung P2270 22" Widescreen LCD Monitor
ok, put all this into an antec sonata case and it all went to plan.
Installed win7 home.
Installed win updates.
Installed ati drivers.
After about 10 minutes screen went fuzy then blanked out and came back on with a "driver not responding error".
so, started prime 95 and got an instant fatal error.
booted into memtest and found that one stick is faulty so the ram will be going back.
Took out the faulty ram so only using 1 stick of ram.
Started up l4d2 and played for an hour and a half with no problems.
Quit game to desktop and im not getting constant "display driver not reponding" messages.
i would send the card back too but ive read that it could be a driver issue and i dont want to waste money on an rma to get told theres nothing wrong with the card.
Any help very much apprieciated.
