specs: Q9550 @4ghz
4GB DDR2 corsair Dominator 1066 ram undercloked to 952 mhz
asus p5q Deluxe
nvidia 295
850 watt coolermaster PSU
hia got a big problem. ive had my system at the current clocks for a good while now and during the last couple of days ive been getting weird system lock ups/stutters during videos like youtube, HDD stored TV/movies etc and gaming.
ive tested dropping CPU speed down to 3.5 and have ram at auto to see if it was down to this paticular OC but i still get sever lockup/stuttering.
let me clarify what i mean by stutters/lock ups. for example, when im playing bad company 2 it will run fine for a few mins, then all of a sudden teh game will freeze and stutter at 1 frame every 15 seconds or so, every now and then the display will go black as if the VGA connection has been removed and will display "analogue", "digital" in top left corner of monitor which usually indicates display connection issues. the image reappers eventually and then im back to desktop, but it will still be virtually unresponsive and continue to flash. i have no choice but to restat computer either by a hard reset, or a long wait for windows to shut down for me via a brief press of the power button. doesnt really seem like a common hardware failur as i havent seen a BSOD yet and as windows will shut down itself.
ive had this issue before a few months back and was resolved via a MB bios update. tried that approach this time but no success.
i think it may be a ram issue but as stated above it is underclocked and when system is at defaullt clocks it runs fine. ram at default is 1066 MHZ so that causes a lot of confusion.
have tried ram in differnt slots and on there own, all be it a brief go on there own. i will try that agagin to see if its a single stick of ram but seeing as though when sticks are at 1066 they run fine as oppossed to 952
Vcore is 1.31 (1.30 after Vdrop)
men voltage is 2.1 as required
any ideas. thanks
asus p5q Deluxe
nvidia 295
any ideas. thanks
